TBS blind scan tools
Postby mounir39 » Mon Feb 22, 2016 8:30 pm
Hello every one,
I have tbs blind scan tool v3.0.1.9 ,i fixed my dish onto eutelsat 5west
and i want to lock multi-stream transponder is there any program help me
to get MIS code because blind scan doesn't.
by the way, there some websites have the code, how did they get it ?
mounir39
Re: TBS blind scan tools
Postby SergioDanielG » Mon Feb 22, 2016 9:04 pm
Hi mounir39.
TBS BlindScan Tool only find active transponders, nothing else. To see more data or in your case, lock signals, you can use TS Recorder (you can download it from http://www.tbsdtv.com/download/document ... .0.1.3.zip )
This is an example of tsrecorder, at end is Input Stream Identify (when there are data)
Kind regards
SergioDanielG
Postby mounir39 » Mon Feb 22, 2016 9:12 pm
thank you for your quick reply SergioDanielG
i have downloaded ts recorder but it doesn't work, i do not known why, and all other programs of tbs work well
mounir39
Postby SergioDanielG » Mon Feb 22, 2016 9:34 pm
Do you have same ts recorder version?
The link I give you is from download section of tbs6983, or are you using other tbs card?
Additionally, do you have some data about what doesn't work? Installation? Doesn't start? Crash at start? Crash when try to lock signal?
Kind regards.
SergioDanielG
Postby mounir39 » Mon Feb 22, 2016 9:47 pm
i have tried ts recorder v 3.0.1.3
this what i get
http://store1.up-00.com/2016-02/14561470650121.png
mounir39
Postby SergioDanielG » Mon Feb 22, 2016 10:01 pm
Did you or can you run it as administrator?
Which version of windows are you using?
I use ts recorder in windows 10 and I used it on windows 7, allways as administrator (I don't really remember why).
Kind regards.
SergioDanielG
Postby mounir39 » Mon Feb 22, 2016 10:19 pm
i have TBS 6983, windows 7
i will try as administrator
mounir39
Postby mounir39 » Mon Feb 22, 2016 10:36 pm
as administrator the same thing
in save mode , it opened but doesn't detect any device
mounir39
