The STV6120 data says it works from 250-2150MHz. Crazyscan, TBS etc will not allow <950MHz Is there any way to get the TBS6983 to tune below 950MHz?
updatelee wrote:You can use my open source drivers to do so. TBS could maybe change it to, it's a simple setting
Dave7 wrote:updatelee wrote:You can use my open source drivers to do so. TBS could maybe change it to, it's a simple setting
Many thanks. I found references to 250MHz in your code when I did a search but I'm a Linux noob. I went through the postings on Rick's forum but ended up a bit confused. Is there and idiots guide? I am using Crazyscan and EBSpro on WinXP & Win 7 but I have Mint 17.2 for the TBS6983 PC or could build a disk for any distro. Do I need Linux 4.1.0-rc3 kernel? If so which distro to you recommend to use as the base?
@TBS - Any chance that you can change the Win drivers? Please?
Dave7 wrote:Hi,
IFStart=250
IFStop=2150
crazycat wrote:specific LOF freq limits for C-band and Ka-band LNB, used for IF Freq calculation:
