Problems installing TBS Drivers
Postby hanssol » Wed Mar 23, 2016 9:09 pm
I have installed a fresh Centos 7. But when i want to install de TBS drivers i got errors.
[[email protected] ~]# sudo ./v4l/tbs-x86_64.sh
sudo: ./v4l/tbs-x86_64.sh: command not found
[[email protected] ~]# cd /linux-tbs-drivers
[[email protected] linux-tbs-drivers]# sudo ./v4l/tbs-x86_64.sh
[[email protected] linux-tbs-drivers]# make
make -C /linux-tbs-drivers/v4l
make[1]: Entering directory `/linux-tbs-drivers/v4l'
Updating/Creating .config
/bin/sh: ./scripts/make_kconfig.pl: /usr/bin/perl: bad interpreter: Permission denied
make[1]: *** [.config] Error 126
make[1]: Leaving directory `/linux-tbs-drivers/v4l'
make: *** [all] Error 2
Please help!
hanssol
Re: Problems installing TBS Drivers
Postby SergioDanielG » Thu Mar 24, 2016 1:23 am
Hi hansool.
hanssol wrote:...
Can you modify this file: v4l/scripts/make_kconfig.pl and change the first line
Code: Select all
#!/usr/bin/perl
to
Code: Select all
#!/usr/bin/env perl
Then try to make again and tell me if it works.
Kind regards.
SergioDanielG
Postby hanssol » Thu Mar 24, 2016 3:46 pm
[[email protected] linux-tbs-drivers]# ./v4l/tbs-x86_64.sh
make -C /root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/tbs/linux-tbs-drivers/v4l'
/usr/bin/env: perl: Permission denied
make[1]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l'
Regards Hanssol
hanssol
Postby hanssol » Thu Mar 24, 2016 4:01 pm
With the make -j4:
[[email protected] linux-tbs-drivers]# make -j4
./scripts/make_kconfig.pl /lib/modules//build /lib/modules//build
scripts/make_makefile.pl
make[1]: execvp: scripts/make_makefile.pl: Permission denied
make[1]: *** [Kconfig] Error 126
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile.media] Error 127
hanssol
Postby hanssol » Sun Mar 27, 2016 4:31 pm
Solved! I installed Ubuntu no it works perfect!
hanssol
Return to MOI Pro - AMD
