TBS6981 sat card not detected in Ubutu 14.04 x64(kernel 4.2)
Postby ChromeQ » Tue Apr 05, 2016 1:25 am
Hi.
After a clean reinstall of my Ubuntu the other week I am having trouble installing the TBS6981 drivers.
I have run through the instructions many times in the past (usually after upgrading the kernel) without any issue but this time it doesn't work. The strange thing is that it worked last week and there have been no changes to the kernel since then.
These are the instructions I followed:
Code: Select all
cd /usr/src/TBS6981
rm -r linux-tbs-drivers
# Have also used older version of the drivers, previously worked with v160219
unzip -q tbs-linux-drivers_v160331.zip
tar -xjf linux-tbs-drivers.tar.bz2
# This patch from http://www.vanbest.org/drupal7/sites/www.vanbest.org/files/linux-3.7.1-dvb-mutex.patch, have tried installing both with and without this line...
patch -p1 <  linux-3.7.1-dvb-mutex.patch
cd linux-tbs-drivers
find -type d -exec chmod 755 \{\} \;
find -type f -exec chmod 644 \{\} \;
find -name '*.sh' -exec chmod 755 \{\} \;
find -name '*.pl' -exec chmod 755 \{\} \;
# Some tutorials mention this line, when it worked previously I needed this line
rm -r -f /lib/modules/$(uname -r)/kernel/drivers/media
./v4l/tbs-x86_64.sh
make
make install
# One tip somewhere also mentioned to try copying the dvb-fe-cx24116.fw in the zip file to /lib/firmware. Was not necessary for the once it did work
cp ../dvb-fe-cx24116.fw /lib/firmware
reboot
The code runs fine with no errors. On reboot the output of dmesg | grep -i dvb shows nothing.
I also once installed an older kernel (3.19) and tried, it worked (only after deleting the /lib/modules/$(uname -r)/kernel/drivers/media folder) so I tried again booting into the 4.2 kernel, that also worked. Now it has disappeared and trying to make and make install seem to work, but shows nothing in bootup.
Please help me install this, and I'm happy to provide any additional details or outputs, I'm just not sure what I'm looking for in logs or where to get the details of this stuff.
Thanks very much
ChromeQ
Re: TBS6981 sat card not detected in Ubutu 14.04 x64(kernel
Postby ChromeQ » Wed Apr 06, 2016 9:04 pm
Here is an output of my dmesg if that will help anybody with more info
http://pastebin.com/f1HKJeqp
And my output of `lspci -v`
http://pastebin.com/aXKP5zpZ
Really am stuck with this one, any suggestions welcome as I am going crazy just constantly reinstalling it
ChromeQ
