LibreELEC 7.0
LibreELEC 7.0
Postby vpeter » Tue Apr 26, 2016 10:51 pm
If anyone is still using TBS Matrix for this purpose here is the image.
With very, very limited support. If it works great, if not ....
Two known bugs:
1) it doesn't work with some TV's (no signal)
2) powering down sometimes doesn0t work
LibreELEC-imx6.arm-7.0.0-matrix.tar
https://drive.google.com/folderview?id= ... aring#list
As you may know some developers forked openelec project and created LibreELEC. We just hit our first release: https://libreelec.tv/2016/04/libreelec- ... 0-release/
There is also some imx6 support and I'm wondering if I should make also image for TBS Matrix system?
I remember there were some boot issues which would be nice to fix. Can someone describe them with reference to old threads?
vpeter
Re: LibreELEC 7.0
Postby ddjpp » Wed Apr 27, 2016 12:16 am
Hi Peter!!
will not work if we do the update ;
remember to had problem with the led and fan speed.
ddjpp
Re: LibreELEC 7.0
Postby vpeter » Wed Apr 27, 2016 12:18 am
ddjpp wrote:will not work if we do the update ;
Should work with update. But I always do fresh install (it is easier).
What led/fan issue? Can you find me a thread.
vpeter
Re: LibreELEC 7.0
Postby buddyrm » Fri May 06, 2016 1:07 am
Tried the update with the new system and kernel from LibreELEC 7.0 imx6 release. It does not boot. Just incase someone wants to try this.
buddyrm
Re: LibreELEC 7.0
Postby vpeter » Fri May 06, 2016 1:34 am
buddyrm wrote:Tried the update with the new system and kernel from LibreELEC 7.0 imx6 release. It does not boot. Just incase someone wants to try this.
Did someone wrote there is working image for matrix? No. SO this is the result ;)
vpeter
Re: LibreELEC 7.0
Postby buddyrm » Fri May 06, 2016 1:59 am
Sorry then, misunderstood. :-(
buddyrm
Re: LibreELEC 7.0
Postby vpeter » Sat May 14, 2016 10:42 pm
Firs post updated. Read carefully!
vpeter
Re: LibreELEC 7.0
Postby buddyrm » Wed May 18, 2016 9:51 pm
vpeter wrote:Firs post updated. Read carefully!
Great, will install and get back to you on the results.
buddyrm
Re: LibreELEC 7.0
Postby buddyrm » Thu Jun 02, 2016 10:56 pm
So I installed it and it seems to work except I can not setup the wireless network. When I try to click on Librelec to setup network settings. It says the plugin is not ready yet and try again later. So I am stuck now. How do I setup the wireless network.?
buddyrm
Return to Announcements
