6909 issue - 1 tuner has error,
Postby snailbrain » Fri May 20, 2016 9:04 am
I've just received my card in quick time from tbs
i've installed the drivers successfully on ubuntu 14.04 server
when i do lsdvb i get >
Code: Select all
lsdvb
                Version: 0.0.4
                Copyright (C) Manu Abraham
TBS PCIE (544:6178 6909:1) on PCI Domain:0 Bus:3 Device:0 Function:0
        DEVICE:0 ADAPTER:4 ERROR: Open frontend0 failed
is this normal? ignored the error and installed tvheadend..
also note i enabled mode 0
in tvheadend i don't seem to have the control over the 4th tuner? (so i can't set diseqc etc for it to be a master tuner, and then use tuner 5 as it's slave)
any ideas?
snailbrain
Re: 6909 issue - 1 tuner not working?
Postby snailbrain » Fri May 20, 2016 9:16 am
i'm using the latest drivers
also do i need to do this? https://tvheadend.org/projects/tvheadend/wiki/TBS6985
i'm trying to tune with the first 4 tuners but seems only tuners 0 and 1 are getting a signal atm. at first all of them were
snailbrain
Postby snailbrain » Fri May 20, 2016 3:29 pm
snailbrain wrote:i'm using the latest drivers
missing lots of channels after leaving it scanning with the 2 working tuners overnight
do i need to enable linked input on tvheadend?
any tips on settings i need to use? --
my setup consists of :
28.2e, 19.2e,13e - quad lnb on each
all go to 4x disqec switches
the output from each switch go to 6909 in mode 0.
The setup works fine on my TBS dual tuner (6982) and TT-budget S2-4100, and have done for a couple of years.
Code: Select all
dmesg |grep dvb
[    8.529731] dvb_core: module verification failed: signature and/or required key missing - tainting kernel
Code: Select all
 dmesg |grep frontend
[   35.912947] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   36.227148] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   36.539392] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   36.851684] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   37.163880] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   37.476149] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   37.788392] DVB: registering adapter 6 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   38.101937] DVB: registering adapter 7 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
snailbrain
Postby guacharaca » Fri May 20, 2016 9:11 pm
I suspect you have a set-up problem. Your set-up of TVH looks different that what I have, but I am in Canada. Try the following: In the "Sat config" drop-down menu where you have "4-port switch", change that to "Advanced (non-universal LNBs, rotors, etc.)". Press "save". Then in the new directory that appears, in "Orbital positions:" put "1". Press "save". In the new directory that appears, choose the "LNB type" to that which exactly matches your lnb. (I am using HTS Tvheadend 4.1-1363~ga46818c)
guacharaca
Postby snailbrain » Fri May 20, 2016 11:56 pm
thanks for the reponse
i can do this but what about adapter 4 and 5, none of them have the option yet they are supposed to share the same input. i should have the option to select satellite config for one of them (adapter 4).
I wonder if adapter 4 is faulty.. although i'm also having issue tunning as well.
any help greatly appreciated.
i'm using HTS Tvheadend 4.1-2051~gc514879~trusty
snailbrain
Postby snailbrain » Sat May 21, 2016 12:16 am
i just at least sorted what looked a bit of a weird list of tuners..
i reinstalled tvh it all shows "normal" for what i am used to.
I will now set every other tuner as a slave and let you know.
The issue was because i installed tvheadend and tbs drivers, and then swapped to Mode 0 from Mode 1.. this probably caused some confusion to TVH.
seems to look ok now
we'll see how far i get tuning the 3 satellites now :)
(note, i still have the error in lsdvb)
snailbrain
Postby snailbrain » Sat May 21, 2016 12:27 am
ahh, after setting master and slave tuners, it defaults to that look after you restart the service (or maybe even refresh the page completely)
i'll create a new thread with the next issues
snailbrain
Re: 6909 issue - 1 tuner has error,
Postby snailbrain » Sat May 21, 2016 7:19 am
dodgy tuner?
Code: Select all
dmesg | tail
[   38.365319] DVB: registering adapter 6 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   38.365411] DVB: registering new adapter (TBS PCIE DVB Adapter)
[   38.365768] TurboSight TBS 6909 Frontend Attaching...
[   38.365770] DEBUG_MODE: 0
[   38.678855] TurboSight TBS6909 MAC Addresses: 00:22:ab:91:1a:78 - 00:22:ab:91:1a:7f
[   38.678860] DVB: registering adapter 7 frontend 0 (TurboSight TBS 6909 DVBS/S2 frontend)...
[   43.484761] TurboSight TBS 6909 Frontend:
[   43.484761]  tbs6909fe - LNB Off, Port4 Still In Use: 18V
[   43.488747] TurboSight TBS 6909 Frontend:
[   43.488747]  tbs6909fe - LNB Off, Port4 Still In Use: 18V
snailbrain
Users browsing this forum: Google [Bot] and 0 guests
