WARNING: filter timeout pid
Postby mchakroun » Thu Jun 30, 2016 9:04 pm
When I try to scan I have this output, if I try 12090000 V 29700000 5/6 35 QPSK it works liek a charm. Someone can help me to figure out how to fix ?
Code: Select all
initial transponder DVB-S  12129000 V 29700000 5/6 35 QPSK
initial transponder DVB-S2 12129000 V 29700000 5/6 35 QPSK
>>> tune to: 12129:vC56M2O35S0:S0.0W:29700:
DiSEqC: uncommitted switch pos 0
DiSEqC: switch pos 0, 13V, hiband (index 2)
DVB-S IF freq is 1529000
>>> tuning status == 0x1F
WARNING: filter timeout pid 0x0010
dumping lists (0 services)
Done.
#uname -a
Linux 3.19.0-64-generic #72~14.04.1-Ubuntu SMP Fri Jun 24 17:59:48 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Regards
mchakroun
Re: WARNING: filter timeout pid
Postby guacharaca » Sat Jul 09, 2016 1:40 am
I do not know the answer. However to troubleshoot, two things I would try independently: 1) Change "hiband" to normal kuband in the adapter settings. 2) Figure out why you are getting "DVB-S IF freq is 1529000" when you typed in "29700000".
guacharaca
