New Arrival TBS6522 Windows Driver V1.0.0.2 is Released!
Postby Jenny » Thu Jul 07, 2016 11:56 am
Dear All,
Here comes a good news for you:
TBS6522 Muti-standard Dual PCI Express TV tuner card
New Arrival TBS6522 supports multiple digital TV standards including ISDB-T/DVB T2/C2/S2X/S2/T/C/S and enables you to watch TV channel from one transponder/satellite while recording another channel from other transponder/ satellite at the same time. It can be used for data receiving, IPTV streaming, media monitoring and digital content distribution.
This multi-standard dual tuner PCIe card is access to EPG (Electronic Program Guide) support. 8-)
The Four RF INs are independent with each other. With this multi-standard TV tuner card, a switchover between different digital TV signals is much easier to operate. you just need to plug another signal cable instead of taking out the card from your server. With two tuners, the TBS6522 enables you to watch TV channel from one transponder/satellite while recording another channel from another transponder/ satellite at the same time.
TBS6522 Windows driver V1.0.0.2 is released! You can download the Windows driver and its mode change app on the following links:
Windows Driver:
http://www.tbsdtv.com/download/document/tbs6522/tbs6522-windows-driver_v1.0.0.2.zip
Mode Change Tool:
http://www.tbsdtv.com/download/document/tbs6522/tbs6522_changemode_tool_v1.0.0.1.zip
Online Orders:
http://www.tbsdtv.com/products/tbs6522_multi-standard_dual_tuner_pcie_card.html
Thanks for your attention and support. ;)
Best Regards,
Jenny
TBS Technology
Jenny
Re: New Arrival TBS6522 Windows Driver V1.0.0.2 is Released!
Postby mounir39 » Tue Aug 02, 2016 5:00 am
Hi;
it seems a good card
I am looking to buy one
do it support dvb-s2x with 128APSK or 64APSK ?
mounir39
Postby Jenny » Thu Aug 04, 2016 4:10 pm
Thanks for your question. TBS6522 Muti-standard Dual Tuner PCI-e card supports VCM, CCM, QPSK, 8PSK, 16APSK, 32APSK, but not 128APSK or 64APSK. And its maximal symbol rates are as follows: 45M for 8PSK、16APSK, 40M for 32APSK.
Hope you have fun with multi-standard TV tuner PCI-e Card! Have a nice day!
Best Regards,
Jenny
Jenny
