Home > Products > Trans-modulator > DVB/ATSC-T/QAM-B > TBS8112 DVB-S/S2/S2X TO DVB-T Trans-Modulator 4 satellite TV frequencies input and 4 terrestrial TV frequencies output
    TBS8112 is a compact trans-modulation device that is used to convert free DVB-S/S2/S2X satellite TV channels to DVB-T (Digital Terrestrial Television) format. It supports to receive free satellite channels from 4 frequencies via 4 RF port, and output DVB-T channels in 4 frequencies.
    To meet customers' various requirements, TBS8112 DVB-S/S2/S2X to DVB-T trans-modulator also supports IP streams input and local video file storage. With "Remux" technology, you can randomly select required channels from input streams or local video files, then multiplexed to a new TS stream and output in 4 DVB-T Frequencies.
    TBS8112 DVB-S/S2/S2X to DVB-T trans-modulator supports NMS system, can be controlled and configured via Ethernet using a standard browser.
    Main Features
    • DVB-S/S2/S2X to DVB-T trans-modulator: 4 frequencies DVB-S/S2 input and 4 frequencies DVB-T output
    • MAX 108M DVB-T TS output available in 4 frequencies.
    • Smart channel "REMUX" system supports modulating and multiplexing functions
    • RF input/output - type F
    • 1Gb onboard Ethernet – RJ45 for web control and IP streaming
    • Web control and SNMP agent
    • Robust mountable housing
    TBS TV Tuner PCIe
    TBS TV Tuner USB
    Copyright © TBS Technologies 2005-2022 All Rights Reserved.
