HI,
I have a very strange issue with the Qbox 2 and could not find any other reference to it or anything similar.
I am currently setting up a 7MCE system to replace the soon to be defunct TIVO system and the satellite solution I have chosen is a Qbox 2 to be used with a DVB-T device which will be integrated with windows 7 via DVBLINK TVSOURCE from DVBLOGIC.
This all works wonderfully well on my test box, ACER Revo 3600, with the exception of the HD channels which stutter and thrash the machine to 100%. This is to be expected has the machine is a single core 1.6 GHz machine. The Revo runs windows 7 ultimate, 32 bit.
Now everything is proven I needed a faster machine to go live on and decided to buy a dual core laptop. This is an Acer Aspire 5741Z that is running Windows 7 Home premium 64 bit.
I ran through the same install process starting with the driver install from the CD and then installed the CD copy of TVSOURCE. The drivers installed perfectly, or at least it seemed that way, and TVSOURCE picks up the tuner correctly. I can then add it and assign Astra 2 has the headend. The issue is that when I perform a scan, no channels are found. I have tried installing the DVB dream and the TBSviewer with the same result. The device is detected but the channels scan finds nothing. It is as if it can see the card correctly but can actually use it. I tried the latest driver form the download but it gave the same results.
I have tried installing the same 32 bit version of windows ultimate that I use on the Revo but this gives exactly the same results.
I don’t think there is anything wrong with the Qbox or the drivers as everything works perfectly on the Revo Net top. The only difference I see is the 64 Bit architecture on the laptop but installing the 32 Bit should have ruled that out.
Any ideas, can the laptop be faulty given it works perfectly with the DVB-T USB device?
The only difference between the USB devices is that the DVB-T is powered by the laptop only where the Qbox is externally powered.
Thanks in advance
Mark
