LibreELEC (Krypton) v7.90.008
Re: LibreELEC (Krypton) v7.90.008
Postby buddyrm » Sat Nov 12, 2016 3:21 am
vpeter Wrote:After reinstall wizard should be shown as always. No idea what happened in your case.
Here is a video of the file. Down load and see what happens on first boot.
https://ufile.io/d2728
buddyrm
Postby buddyrm » Sat Nov 12, 2016 3:37 am
And here is the screen snapshot of the LibeELEC config addon when you try to run it for the first time.
buddyrm
Postby vpeter » Sat Nov 12, 2016 3:45 am
Seems your system is something completely different and maybe that's why all this troubles. Can't really help with this.
vpeter
Postby buddyrm » Sat Nov 12, 2016 4:19 am
vpeter Wrote:Seems your system is something completely different and maybe that's why all this troubles. Can't really help with this.
Maybe it is the Version 1.3 Looks like it is waiting for some hardware readiness that never finished. :-(
buddyrm
Postby buddyrm » Sat Nov 12, 2016 4:29 am
I got ssh enabled but the root passowrd is not openelec as the default. Do you know the passoword for root on this build?
buddyrm
Postby buddyrm » Sat Nov 12, 2016 4:33 am
buddyrm Wrote:I got ssh enabled but the root passowrd is not openelec as the default. Do you know the passoword for root on this build?
Never mind, got it. :-(
buddyrm
Postby fdt38 » Thu Nov 17, 2016 12:13 am
Thanks vpeter for the package. I am using v7.90.005 Alpha on a daily basis and will switch to the v7.90.008.
Happy with it, works almost fine, with a few crashes.
I would be really pleased to use the TBS5220 USB Tuner I bought with the 2910 box (V2.1).
Unfortunately I have never managed to make it working with the MAtrixTV software :(
(was able to see the device in TvHeadEnd, but unable to list channels).
I guess no driver is available and usable with LibreELEC... (?)
fdt38
Postby vpeter » Thu Nov 17, 2016 2:06 am
Will try to make something. No promises.
Seems driver is here https://github.com/tbsdtv/linux_media but no 3.14 kernel support.
vpeter
Postby vpeter » Fri Nov 18, 2016 7:34 pm
fdt38, try this version.
vpeter
Postby nanasi » Sun Nov 20, 2016 10:39 pm
buddyrm Wrote:Maybe it is the Version 1.3 Looks like it is waiting for some hardware readiness that never finished. :-(
I suppose that a uninitialized cpu-fuse is the cause for the phenomenon.
I remember the non-unique MAC-address trouble.
nanasi
PreviousNext
Return to Announcements
