Openelec for MatrixTBS
Re: Openelec for TBS Matrix
Postby vpeter » Thu Sep 11, 2014 2:34 am
It's time for new OpenELEC version for our TBS Matrix. After some consideration about future of this project we decided to move to common iMX6 project for OpenELEC which will cover all iMX6 based devices.
And here are two images: one Helix based and one Gotham based.
The installation is simple: just download the file, unpack and run MfgTool2-reinstall_vX.bat. As before.
Download link: http://l.bitcasa.com/yvfGcXvL
For tvheadend 3.9 there are some problems and service doesn't start. To fix that some folders must be deleted/moved.
This needs to be run in ssh console:
systemctl stop service.multimedia.tvheadend
mv /storage/.xbmc/addons/service.multimedia.tvheadend/xmltv-config /storage/.xbmc/addons/service.multimedia.tvheadend/xmltv-config-orig
rm -fr /storage/.xbmc/userdata/addon_data/service.multimedia.tvheadend/xmltv
systemctl start service.multimedia.tvheadend
vpeter
Re: Openelec for MatrixTBS
Postby diabloss » Fri Sep 12, 2014 12:53 am
excellent work Peter
diabloss
Postby javanphi » Fri Sep 12, 2014 4:39 am
Hello everyone,
First of all thank you for the excellent work you do on this case.
I just installed OpenELEC-TBS-Matrix-iMX6.arm-devel-20140910145440-r19210-g2d9c62b-Gotham and I have some bug
And with this version in the audio setup, the SPDIF option no longer appears at the passthrough in XBMC? So no way for me to read DolbyDigital or DTS content.
And when I want to shut down or restart via XBMC I see that it will run but the box does not power off.
I am forced to turn it off from ssh
Have you any idea?
javanphi
Postby vpeter » Fri Sep 12, 2014 4:11 pm
javanphi Wrote:the SPDIF option no longer appears at the passthrough in XBMC
This I must check.
javanphi Wrote:when I want to shut down or restart via XBMC I see that it will run but the box does not power off
Seems I forgot to include one patch for this to work. Will fix that in a day or two.
vpeter
Postby vpeter » Sun Sep 14, 2014 2:55 am
Gotham with fixed shutdown: http://l.bitcasa.com/nEsFIXJS
The problem with SPDIF is harder. I noticed that Linux kernel we use doesn't have spdif in it's device tree for sabresd platform. I'm trying to fix that. I wish manufactures would have more interest in supporting basic things. Seems no one cares about sabresd imx6 platform and tbs matrix board.
vpeter
Postby nwagenaar » Sun Sep 14, 2014 6:10 am
I haven't used the latest Gotham release from tonight, but the one you posted a couple of days ago; doesn't seem to activate SSH (and yes, I selected it). Also adding the ssh_enable textfile and rebooting the device didn't seem to work.
Can anybody reproduce this with their 2.1 edition of the MatrixTBS? Also, does this edition have a regular kernel so we can use non-TBS DVB-devices?
nwagenaar
Postby vpeter » Sun Sep 14, 2014 3:36 pm
nwagenaar Wrote:doesn't seem to activate SSH
SSH is enabled by default from bootloader arguments. It should always work - assuming the system boots properly.
nwagenaar Wrote:Also, does this edition have a regular kernel so we can use non-TBS DVB-devices?
Openelec uses it's own kernel. With iMX6 project we have 3.14.18 the same as Cubox-i use. There are some dvb tuners enabled. Of course there will be no support for TBS tuners (which is little ironic).
vpeter
Postby vpeter » Sun Sep 14, 2014 5:45 pm
Gotham with shutdown and spdif: http://l.bitcasa.com/wU2Kid3S
Works with my equipment.
Helix is not updated. If someone wants that let me know.
vpeter
Postby nwagenaar » Sun Sep 14, 2014 7:07 pm
[edit]
I got it working:
I added coherent_pool=2M to the bootargs in the uEnv-matrix-v2.txt
[/edit]
I upgraded my Matrix with the latest version and that seems to have solved my issues with SSH. However, my DVB-S cards were detected but didn't show up in the /dev/dvb tree:
[ 7.172751] technisat-usb2: set alternate setting
[ 7.179894] technisat-usb2: firmware version: 17.63
[ 7.179923] dvb-usb: found a 'Technisat SkyStar USB HD (DVB-S/S2)' in warm state.
[ 7.181165] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7.182796] ERROR: 256 KiB atomic DMA coherent pool is too small!
[ 7.182796] Please increase it with coherent_pool= kernel parameter!
[ 7.183316] dvb-usb: Technisat SkyStar USB HD (DVB-S/S2) error while loading driver (-12)
[ 7.183487] usbcore: registered new interface driver dvb_usb_technisat_usb2
[ 285.942191] usb 1-1.2: new high-speed USB device number 6 using ci_hdrc
[ 286.560311] usb 1-1.2: New USB device found, idVendor=0b48, idProduct=300a
[ 286.560342] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 286.560364] usb 1-1.2: Product: TT-USB2.0
[ 286.560381] usb 1-1.2: Manufacturer: TechnoTrend
[ 286.560399] usb 1-1.2: SerialNumber: LHJCIÃ
[ 286.599241] dvb-usb: found a 'Technotrend TT Connect S2-3650-CI' in warm state.
[ 286.599289] pctv452e: pctv452e_power_ctrl: 1
[ 286.599289]
[ 286.601603] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 286.602888] dvb-usb: Technotrend TT Connect S2-3650-CI error while loading driver (-12)
[ 286.603101] usbcore: registered new interface driver pctv452e
nwagenaar
Postby franky384 » Mon Sep 15, 2014 4:32 pm
Just installed the new version and it works o.o.t.b. with my mystique/dvbsky S960 USB-Tuner:
[ 7.273533] usb 1-1.4: dvb_usb_v2: found a 'DVBSky S960/S860' in warm state
[ 7.278091] usb 1-1.4: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 7.278332] DVB: registering new adapter (DVBSky S960/S860)
[ 7.280394] dvbsky_usb MAC address=00:17:42:54:96:0c
[ 7.280420] usb 1-1.4: dvb_usb_v2: MAC address: 00:17:42:54:96:0c
[ 7.403092] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 7.432722] DS3000 chip version: d0 attached.
[ 7.434021] TS202x chip version[1]: c1 attached.
[ 7.443271] TS202x chip version[2]: c3 attached.
[ 7.465917] usbcore: registered new interface driver r8188eu
[ 7.496567] dvbsky_m88ds3103_load_firmware: Waiting for firmware upload (dvb-fe-ds3103.fw)...
[ 7.503287] dvbsky_m88ds3103_load_firmware: Waiting for firmware upload(2)...
[ 7.559877] systemd-journald[230]: Received request to flush runtime journal from PID 1
[ 7.903089] input: eventlircd as /devices/virtual/input/input7
[ 8.176434] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:04, irq=-1)
[ 8.176629] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.660662] usb 1-1.4: DVB: registering adapter 0 frontend 0 (Montage DS3103/TS2022)...
[ 8.665371] Registered IR keymap rc-dvbsky
[ 8.665739] input: DVBSky S960/S860 as /devices/soc0/soc.1/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/rc/rc1/input9
[ 8.666012] rc1: DVBSky S960/S860 as /devices/soc0/soc.1/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.4/rc/rc1
[ 8.666031] usb 1-1.4: dvb_usb_v2: schedule remote query interval to 300 msecs
[ 8.666044] usb 1-1.4: dvb_usb_v2: 'DVBSky S960/S860' successfully initialized and connected
[ 8.666159] usbcore: registered new interface driver dvb_usb_dvbsky
[ 12.189013] libphy: 2188000.ethernet:04 - Link is Up - 1000/Full
[ 12.189044] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
THANKS FOR YOUR GREAT WORK !!
franky384
PreviousNext
Return to Announcements
