OpenELEC 5.0.4
Re: OpenELEC 5.0.4
Postby Dragonway » Mon May 11, 2015 2:14 am
Ok and thanks vpeter. Lost hope? Sorry for that.
Dragonway
Re: OpenELEC 5.0.4
Postby vpeter » Mon May 11, 2015 2:19 am
Dragonway Wrote:Lost hope? Sorry for that.
Yes, you can read more here if you care.
vpeter
Re: OpenELEC 5.0.4
Postby Dragonway » Mon May 11, 2015 2:23 am
Ok I will read carefully
Dragonway
Re: OpenELEC 5.0.4
Postby vpeter » Fri May 15, 2015 4:21 pm
There is a progress to include all required changes to official OpenELEC. Soon I will prepare new openelec image. Stay tuned :P
vpeter
Re: OpenELEC 5.0.4
Postby MikeDotBe » Fri May 15, 2015 6:10 pm
we are all hanging to your lips (is that the correct english expression?)
mike
MikeDotBe
Re: OpenELEC 5.0.4
Postby Dragonway » Sat May 16, 2015 12:47 am
Ok vpeter super :)
Dragonway
Re: OpenELEC 5.0.4
Postby PeterB » Sat May 16, 2015 8:48 am
This is really great news - I am almost on the point of abandoning my TBS 2910 units ... especially with OE v6 now in beta.
One of my boxes appears to have corrupted its emmc image, and will no longer boot - perhaps I will find the enthusiasm to boot from SD again, and recover it.
One minor issue that I have with both units is that the sound system seems to re-initialise itself at random (or the unit goes through a full reset, but doesn't invoke the auto hdmi switching on the TV?)) even when the system is sitting idle. This is annoying because I use an auto s/pdif switch - this results in the Matrix grabbing attention of the switch and muting the device (usually a sat receiver) which is in active use.
PeterB
Re: OpenELEC 5.0.4
Postby vpeter » Sun May 17, 2015 1:02 am
Dragonway Wrote:i want to try you multiboot patch but i don't now install an os to my sd-card
https://drive.google.com/folderview?id= ... sp=sharing
Download this image and unpack it. Then write it to sd card with Win32 Disk Imager program - I tested with micro sd.
Btw: this is current master with Kodi 15.0 Isengard ;) Not tested much, only to see if it works.
vpeter
Re: OpenELEC 5.0.4
Postby Dragonway » Sun May 17, 2015 2:02 am
Ok and thanks vpeter!.! Win32DiskImager powa. I test :)
Dragonway
Re: OpenELEC 5.0.4
Postby Dragonway » Sun May 17, 2015 2:53 am
PERFECT! No bug and fluid. i transfert backup openelec and see :) the last android run multiboot if sd insert?
Dragonway
PreviousNext
Return to Announcements
Users browsing this forum: Bing [Bot] and 10 guests
