wondering what version of oscam is used now in the matrix box ... i see no informations about oscam version.
asking because i have found patch that can add emu support to almost any version of oscam.
diabloss Wrote:wondering what version of oscam is used now in the matrix box ... i see no informations about oscam version.
opkg list
Cjcr Wrote:Hi @mijanek, looks like there isn't dvb tbs drivers for their devices (like tbs5925 I have got). Can you check it?
mijanek Wrote:Cjcr Wrote:Hi @mijanek, looks like there isn't dvb tbs drivers for their devices (like tbs5925 I have got). Can you check it?
Hi Cjcr, i discovered, that in the kernel used by matrixtv project, teher are some prebuild libs for their dvb devices. I took now this one and made new kernel (whith all latest imx patches) so you may try it out, whenever your device gets recognized. By the way I foud out, that I ommitted the WiFi driver too, so thisone should be also included..
I didn't tested it yet, but here is it..
@diabloss, I made new oscam version with your requested patch, so you may try it out. (I can't test it, as i don't use it)
usb 2-1.1: USB disconnect, device number 8
usb 2-1.1: new high speed USB device number 9 using fsl-ehci
usb 2-1.1: USB disconnect, device number 9
usb 2-1.1: new high speed USB device number 10 using fsl-ehci
[root@matrixtv ~]#
diabloss Wrote:Did you tried mijanek.?
