add EPG to dvblast flow
Postby kalashnikov » Wed Oct 18, 2023 5:44 am
hi
I am using dvblast to send the video stream to another server.
EPG data is not sent
When you verify the executed command line, you notice that the EPG configuration is missing, which is -e
If I run the command manually with the EPG -e option it works fine.
dvblast_1 -f 473000000 -b 6 -m qam_64 -a 1 -e -c /root/dvblast_1.conf
Which of these files should I modify to add the -e option (EPG)?
/usr/bin/initstartdvblast.sh ?
or the cgi located on
/usr/local/tur/apache2.4.3/htdocs/www/cgi-bin/ ?
or some other file?
Thanks for the help
kalashnikov
Re: add EPG to dvblast flow
Postby kalashnikov » Thu Oct 19, 2023 5:39 am
hi
the file to mod is
/usr/local/tur/apache2.4.3/htdocs/www/cgi-bin/streaming_T.cgi
at line 145 just add -e
kalashnikov
Return to MOI+
Users browsing this forum: No registered users and 26 guests
