Thanks for this version. It fixes the 2nd stream problem, however it brings back the audio glitches (brief sound gaps) of version 1.0.12, they happen with varying intensity, sometimes depending on content (with background music) about every 5 to 10 seconds.
These audio glitches are quite annoying, they happen under all parameters that I tried (h.264 or h.265, VBR or CBR, 1024 kbp or 12000 kbps). Because of the audio problem I'll stick for now to version 1.0.39, it's more watchable.
If needed I can capture a sample video with the audio glitches for your consideration.
