System requirements TBS6980
Re: System requirements TBS6980
Postby cody » Fri Feb 25, 2011 9:35 pm
Volture Wrote:I haven't yet had the time to place the screenshots online. I did however check my CPU capacity when watching SD or HD content through Vista Media Center. I noticed that my dual core was @ 90%+ both times, for both cores. It looks like there is no hardware accelleration used in the decompression of the MPEG2 of MPEG4 streams.
Am I right? If so, how do I solve this?
you're absolutely right, because with your video card and active hardware acceleration you should get close to 0% CPU load for video decoding, but less than 10% for sure. i can't suggest anything definitive since it's video card issue and an issue specific to TBS hardware, but in your case i would start with upgrading/downgrading the video card drivers as well as ask AMD/ATi support for some suggestions how to diagnose why their video acceleration is not indeed active.
Previous
