No signal after resume from sleep
Re: No signal after resume from sleep
Postby HFamilyDad » Sat Oct 15, 2011 3:55 am
I'm experiencing this problem and have found the new drivers 2.0.0.21 do not work.
Is there any news on this yet as it appears other users are still not satisfied with these drivers.
I'm using
ASUS P5N7A-VM m/b
GIGABYTE GTX560Ti OC
Win 7 64
Ill be happy to supply more info if required.
HFamilyDad
Postby kevin » Fri Oct 21, 2011 4:18 am
Hi, I believe I am suffering the same problem. I use MediaPortal and sometimes when the PC restarts to record the recording appears to work from an MediaPortal view (i.e. it logs that it is recording BUT the file produced is small and not valid. Other times when I just want to use MediaPortal to view TV MediaPortal reports "no signal". Rebooting fixes the problem. All the evidence suggests that after resume the card isn't properly reinitialised
Would really appreciate a fix
kevin
Previous
