[ Moderator Control Panel ]
by alexxm » Thu Apr 11, 2019 2:07 pm
TBS260B IP to ASI Converter work only when I direct connect LAN port to PC.
When I connect this converter via switch it don't work - no ping to 192.168.8.188 and no stream out.
I used different LAN cables and another switches (100M and 1Gb switch), but the is no effect.
Can you help me?
alexxm
by xiaocao » Fri Apr 12, 2019 9:25 am
hi ,
please make sure TBS260B , pc connect to the same switch.
best regards!
xiaocao
Return to TBS260B DVB HD IP to ASI Converter
