Is my tbs 6981 broken?
Postby asdfasf » Wed Mar 17, 2021 7:46 am
I got a 6981 on ebay. Initially I couldn't install the driver. I noticed that I get a different subsystem id than in the guide on linuxtv.org.
According to https://www.linuxtv.org/wiki/index.php/TBS6981 I should get subsystem id Subsystem: Device 6981:8888
on linux I get
06:00.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder [14f1:8852] (rev 04)
Subsystem: Device [1b27:0742]
I cannot install it on windows for the same reason unless I hardcode the subsystem id in the driver to the subsystem id that I got above.
Once I set the card to the number 40 or whatever that was for tbs 6981 in the open source driver everything appears to be running correctly.
I don't have the dish yet. I ordered it but still haven't received it in the mail so I tried to test out my usals rotor. I connected the rotor to the 1st output and tried a couple of different pieces of software to get it to turn with no success.
For some reason I figured I could check the voltage on the cable. I remember that on other cards the cable was electrocuting me lightly and I was always able to feel it when I touched it. I got my multimeter out and measured the voltage. I think it was around 0.5 v dc when I had the pcie power connector plugged in and 0.05 when I didn't have it plugged in. Does it have to be plugged in for the card to operate? Can anyone supply some manual that came with the card? I didn't even get a remote with a card when I bought it.
Is this card even working or am I doing something wrong? I will obviously test if I'm able to receive any signal when I get the dish but I don't wanna waste my time waiting if this card is broken. What's the best way to check it? One thing that I wanted to add is that I was able to see some signal strength being reported in vdr without the cable plugged in so I don't know maybe I'm missing something and the card is operational
here's the dmesg output I get
[89033.162923] cx23885: CORE cx23885[1]: subsystem: 1b27:0742, board: TurboSight TBS 6981 [card=40,insmod option]
[89035.382911] cx25840 6-0044: cx23885 A/V decoder found @ 0x88 (cx23885[1])
[89036.001330] cx25840 6-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[89036.016726] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[89036.016731] cx23885: cx23885[1]: cx23885 based dvb card
[89036.016745] cx24117 5-0055: creating new instance
[89036.016749] i2c i2c-5: cx24117: Attaching frontend 0
[89036.016752] dvbdev: DVB: registering new adapter (cx23885[1])
[89036.016756] cx23885 0000:06:00.0: DVB: registering adapter 0 frontend 0 (Conexant CX24117/CX24132)...
[89036.017320] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[89036.017324] cx23885: cx23885[1]: cx23885 based dvb card
[89036.017331] cx24117 5-0055: attaching existing instance
[89036.017335] i2c i2c-5: cx24117: Attaching frontend 1
[89036.017337] dvbdev: DVB: registering new adapter (cx23885[1])
[89036.017341] cx23885 0000:06:00.0: DVB: registering adapter 1 frontend 0 (Conexant CX24117/CX24132)...
[89036.017983] cx23885: cx23885_dev_checkrevision() Hardware revision = 0xa5
[89036.017990] cx23885: cx23885[1]/0: found at 0000:06:00.0, rev: 4, irq: 60, latency: 0, mmio: 0xfac00000
asdfasf
Users browsing this forum: No registered users and 14 guests
