Hello
I need help, i try to do blindscan using a tbs 6925 but i dont know how to do this.
i've recompiled the driver following the instruction in other post, and everything ok, but when i try using a scan this don't work for me , i think i used a wrong command.
the other question is, to use blind scan i need setup lnb frecuency or something else?
Log from command grep:
[root@test bin]# dmesg | grep SAA716x
SAA716x TBS 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
SAA716x TBS 0000:01:00.0: setting latency timer to 64
DVB: registering new adapter (SAA716x dvb adapter)
Best Regards from Panama
