Blind Scan Parameters
Postby paulus » Thu May 05, 2011 10:17 pm
Good Day Steven,
Along with the diseqc switching issues, I have questions regarding the TBS Blind Scan performance.
What parameters are used within the program (freq steps, signal lock, ect)?
Will it be possible to adjust these parameters in the future?
I have attached a sample of a satellite scan with SmartDVB and the scan results using the blind scan program. I usually have to run the blind scan several times on each polarity and save the scan with the most results. However, there are still not as many TPs being found that should be.
Thanks.
paulus
Re: Blind Scan Parameters
Postby paulus » Tue May 24, 2011 8:29 pm
Bump?
paulus
