winger Wrote:Yes! I will wait! Thank's!!!!!!
sudo modinfo cx23885 -F parm
ci_dbg:Enable CI debugging (int)
ci_irq_enable:Enable IRQ from CAM (int)
ir_888_debug:enable debug messages [CX23888 IR controller] (int)
mpegbufs:number of mpeg buffers, range 2-32 (int)
mpeglines:number of lines in an MPEG buffer, range 2-32 (int)
mpeglinesize:number of bytes in each line of an MPEG buffer, range 512-1024 (int)
v4l_debug:enable V4L debug messages (int)
alt_tuner:Enable alternate tuner configuration (int)
adapter_nr:DVB adapter numbers (array of short)
i2c_debug:enable debug messages [i2c] (int)
i2c_scan:scan i2c bus at insmod time (int)
debug:enable debug messages (int)
card:card type (array of int)
vbibufs:number of vbi buffers, range 2-32 (int)
vbi_debug:enable debug messages [vbi] (int)
video_nr:video device numbers (array of int)
vbi_nr:vbi device numbers (array of int)
radio_nr:radio device numbers (array of int)
video_debug:enable debug messages [video] (int)
irq_debug:enable debug messages [IRQ handler] (int)
vid_limit:capture memory limit in megabytes (int)
netup_card_rev:NetUP Dual DVB-T/C CI card revision (int)
enable_885_ir:Enable integrated IR controller for supported
CX2388[57] boards that are wired for it:
HVR-1250 (reported safe)
TeVii S470 (reported unsafe)
This can cause an interrupt storm with some cards.
Default: 0 [Disabled] (int)
# TBS6925 PCI-e DVB-s2 and TBS6982 PCI-e DVB-s2
#options stv090x adapter_nr=0,1,2
# TBS6920 PCI-e DVB-s2
options cx23885 adapter_nr=3
