Continuity Counter Errors
Re: Continuity Counter Errors
Postby tzimmo » Sat Oct 07, 2017 4:10 pm
> 1) Asus M4A88T-M with TBS6284 quad tuner. Current setup: adapter0=idle, adapter1=hd, adapter2=sd, adapter3=hd. There are no problems with it, no continuity counter errors.
Now I've started experiencing problems with this one as well. Similar symptoms, there are some duplicate packets rarely but still. If I remove a duplicate TS packet (188 bytes), I can often make an identical stream that I get from the other system with the same card but only using 1 our of those 4 tuners on the same adapter.
Quite different kernel versions (Debian 6: 2.6.38-1-amd64 #1 SMP), (Debian 8: 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt11-1+deb8u4) but the same problem.
tzimmo
Previous
