open source driver request for 6922
Re: open source driver request for 6922
Postby jcgeny » Tue May 05, 2015 8:24 pm
the open source driver should have its own subforum...
may be it could be referenced at the official drivers download ? with the difference to the official explained , a bit like the black hole firmware at vu+
beside that , i tried to compile the driver with the Linux Mint Debian 2 , i had few warnings and the last make did not finished well...
here are the last lines of the make command :
LD [M] /root/media_build/v4l/zr364xx.ko
make[2]: Leaving directory '/usr/src/linux-headers-3.16.0-4-amd64'
./scripts/rmmod.pl check
Can't locate Proc/ProcessTable.pm in @INC (you may need to install the Proc::ProcessTable module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/x86_64-linux-gnu/perl5/5.20 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at ./scripts/rmmod.pl line 4.
BEGIN failed--compilation aborted at ./scripts/rmmod.pl line 4.
make[1]: Leaving directory '/root/media_build/v4l'
make: *** [all] Error 2
here is the display when i re-enter make :
blacktv media_build # make
make -C /root/media_build/v4l
make[1]: Entering directory '/root/media_build/v4l'
creating symbolic links...
make -C firmware prep
make[2]: Entering directory '/root/media_build/v4l/firmware'
make[2]: Leaving directory '/root/media_build/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for 'default'.
Kernel build directory is /lib/modules/3.16.0-4-amd64/build
make -C ../linux apply_patches
make[2]: Entering directory '/root/media_build/linux'
Syncing with dir ../../media
Patches for 3.16.0-4-amd64 already applied.
make[2]: Leaving directory '/root/media_build/linux'
make -C /lib/modules/3.16.0-4-amd64/build SUBDIRS=/root/media_build/v4l modules
make[2]: Entering directory '/usr/src/linux-headers-3.16.0-4-amd64'
Makefile:10: *** mixed implicit and normal rules: deprecated syntax
make[1]: Entering directory `/usr/src/linux-headers-3.16.0-4-amd64'
Building modules, stage 2.
MODPOST 606 modules
WARNING: "dma_buf_export" [/root/media_build/v4l/videobuf2-vmalloc.ko] undefined!
WARNING: "dma_buf_export" [/root/media_build/v4l/videobuf2-dma-sg.ko] undefined!
WARNING: "dma_buf_export" [/root/media_build/v4l/videobuf2-dma-contig.ko] undefined!
WARNING: "hdmi_infoframe_log" [/root/media_build/v4l/adv7842.ko] undefined!
WARNING: "hdmi_infoframe_unpack" [/root/media_build/v4l/adv7842.ko] undefined!
what are the distros you tested you driver ?
jcgeny
Postby Alfredo » Thu May 07, 2015 2:46 am
Hi jcgeny
I tested with OpenSuse 13.1 and Debian 7.8.0-amd64-kde.
I have not written the driver. The driver was written by Luis Alves <https://github.com/ljalves>
Sometime the problem is v4l, if you try another day it work, because the people of v4l update your repository.
if you have time, on Debian try: https://bitbucket.org/updatelee/updatedvb and https://bitbucket.org/updatelee/v4l-updatelee. Sometimes work and sometimes not work this blindscan.
Regards
Alfredo
Previous
