Kiwi Wrote:As an interim, can u guys release another signed version of the drivers with the title of the device renamed to "TBS 6280 Dual DVB-T2/T/C BDA Tuners" since this is combined driver supporting also DVB-C?
grapefruit Wrote:Please check for installation bugs too.
I think it will install back the uninstalled drivers when trying to install 1009 or 1010.
Example :
If you uninstalled dvb-t 1008 drivers before installing 1009 or 1010, it will install back 1008 when you install 1009 or 1010 with the setup exe.
If you uninstalled dvb-c 1004 drivers before installing 1009 or 1010, it will install back 1004 when you install 1009 or 1010 with the setup exe.
This is what I have noticed but I'm not 100% sure I 'm correct or not.
But that was why I couldn't get it to work in the first place until I updated the drivers with WIndows Device Manager instead of using the setup.exe.
Thank you.
Opposed to those 1.0.0.9 drivers from the mainpage, the 1.0.1.0 do work for DVB-C and DVB-T. DVB-T(2) not tested.steven Wrote:And Please have a test with this new combine driver DVBT/T2/C:
https://hotfile.com/dl/180246969/6df709 ... r.zip.html
MrFloppy Wrote:Opposed to those 1.0.0.9 drivers from the mainpage, the 1.0.1.0 do work for DVB-C and DVB-T. DVB-T(2) not tested.steven Wrote:And Please have a test with this new combine driver DVBT/T2/C:
Any reason, why these (working ones) are not on the mainpage?
The name, though confusing because of the missing "C", can be easily altered by renaming the device in the TBS6280.inf (to the end). But that's really just cosmetic. (Or through the registry, but if you want a correct name, I'ld recommend just changing the .inf file. Beware: any driver signature shall be lost by changing the driver files; it still works the same.)
Abolutely, but it is really just a cosmetical change. Maybe that's why it's not yet on the main page. Anyway the driver seems to work well for me. And that's what really counts, I guess.Kiwi Wrote:Changing the inf file ..., it's meant to be done by the device driver manufacturers.
MrFloppy Wrote:Abolutely, but it is really just a cosmetical change. Maybe that's why it's not yet on the main page. Anyway the driver seems to work well for me. And that's what really counts, I guess.Kiwi Wrote:Changing the inf file ..., it's meant to be done by the device driver manufacturers.
