[ Moderator Control Panel ]
by admsasha » Wed Nov 05, 2014 1:40 pm
- Code: Select All Code
# ./v4l/tbs-dvbc-x86_64.sh
TBS 62xy, 5880 and 528x drivers configured for DVBC (x86_64 platform).
# make
make -C /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l'
No version yet, using 3.10.51-nrj-desktop-1rosa
make[1]: Leaving directory `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.10.51
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.10.51-nrj-desktop-1rosa/source ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/firmware'
make -C firmware
CC ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.10.51-nrj-desktop-1rosa/build
make -C /lib/modules/3.10.51-nrj-desktop-1rosa/build SUBDIRS=/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l modules
make[2]: Entering directory `/usr/src/linux-3.10.51-nrj-desktop-1rosa'
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/tuner-xc2028.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/tuner-simple.o
--- cut ----
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx23885-f300.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx25840-core.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx25840-audio.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx25840-firmware.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx25840-vbi.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx25840-ir.o
CC [M] /home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/cx88-dvb.o
make[3]: *** Нет правила для сборки цели `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/tbs8921ctrl.o', требуемой для `/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l/tda18271.o'. Останов.
make[2]: *** [_module_/home/mart/drivers/tbs-linux-drivers/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-3.10.51-nrj-desktop-1rosa'
make: *** [all] Error 2
admsasha
by admsasha » Wed Nov 05, 2014 5:20 pm
./v4l/tbs-x86_64.sh Instead of ./v4l/tbs-dvbc-x86_64.sh
and modify line in file saa716x_tbs.h
It was
#define TURBOSIGHT_TBS6221_SUBVENDOR 0x6221
#define TURBOSIGHT_TBS6221_SUBDEVICE 0x0002
It became
#define TURBOSIGHT_TBS6221_SUBDEVICE 0x0001
And on my ROSA 2012.1 run TBS6221 )
admsasha
