Problem with signal strength
Postby marcinm » Wed Nov 07, 2012 8:52 pm
I instelled TBS5680 under the latest Ubuntu:
uname:
Linux Lenovo-G550 3.5.0-17-generic #28-Ubuntu SMP Tue Oct 9 19:32:08 UTC 2012 i686 i686 i686 GNU/Linux
drivers compiled successfully (tbs-linux-drivers_v121105.zip), when connecting device there is nothing worrying in dmesg:
[ 1354.400183] usb 2-5: >new high-speed USB device number 5 using ehci_hcd
[ 1354.533615] usb 2-5: >New USB device found, idVendor=734c, idProduct=5680
[ 1354.533627] usb 2-5: >New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1354.533635] usb 2-5: >Product: TBS 5680
[ 1354.533642] usb 2-5: >Manufacturer: TBS-Tech
[ 1354.646642] IR NEC protocol handler initialized
[ 1354.648341] IR RC5(x) protocol handler initialized
[ 1354.650027] IR RC6 protocol handler initialized
[ 1354.651735] IR JVC protocol handler initialized
[ 1354.657055] IR Sony protocol handler initialized
[ 1354.659385] IR MCE Keyboard/mouse protocol handler initialized
[ 1354.662471] lirc_dev: IR Remote Control driver registered, major 249
[ 1354.663254] IR LIRC bridge handler initialized
[ 1354.671640] dvb-usb: found a 'TBS 5680 CI USB2.0' in cold state, will try to load a firmware
[ 1354.678518] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5680.fw'
[ 1354.681663] tbs5680: start downloading TBS5680 CI firmware
[ 1354.808126] dvb-usb: found a 'TBS 5680 CI USB2.0' in warm state.
[ 1354.808272] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1354.808563] DVB: registering new adapter (TBS 5680 CI USB2.0)
[ 1355.060857] dvb-usb: MAC address: 00:22:xx:xx:xx:xx (edited)
[ 1355.106840] tbs5680fe: module license 'TurboSight Proprietary' taints kernel.
[ 1355.106847] Disabling lock debugging due to kernel taint
[ 1355.130627] tbs5680: Attached TBS5680FE!
[ 1355.130627]
[ 1355.131055] tbs5680: CI initialized.
[ 1355.131357] tbs5680: CI disabled.
[ 1355.131363] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5680 DVBC frontend)...
[ 1355.131944] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-5/input/input14
[ 1355.132535] dvb-usb: schedule remote query interval to 150 msecs.
[ 1355.132543] dvb-usb: TBS 5680 CI USB2.0 successfully initialized and connected.
[ 1355.133004] usbcore: registered new interface driver tbs5680
Performed full scan under Kaffeine and found all available channels. Unfortunatelly, Kaffeine shows the signal strength is at about 20-25% and snr is ~5%.
When watching tv programmes, every single frame is corrupted - you cannot see enything except squares.
I'm sure that my cable provider signal strength is ok, because what am I doing is unplugging cable from tv and plugging it to TBS5680 - my TV (Sony bravia) shows 100% signal strength and about 97% snr. Image quality is perfect, every frame is ok even on HD channels.
I don't think also my laptop is too slow, because I recorded stream directly from card without watching it, and recorded stream looks the same.
Is there anything I can do to watch TV using TBS5680?
marcinm
Re: Problem with signal strength
Postby cody » Thu Nov 08, 2012 4:49 am
Hi, if your 5680 box is new, i.e. you haven't used it before and thus it has never worked good for you then most likely it's just faulty device that slipped thought QA. however, one other less likely option is that your DVB-C signal is too strong and you need to use attenuator or better call cable provider technicians to check its level and lower its strength. so, if dealing with the cable provider for such kind of support is hard to be arrange then better first to replace the box with new one, which can answer the same, i.e. confirm if your first 5680 device is faulty or just signal on your cable is too strong and causes issues.
Postby marcinm » Thu Nov 08, 2012 5:41 am
Thank you for replay, I'll contact the seller - it's new item which already arrived from online store.
marcinm
