I am experiencing a interlacing effect on DVB-T grabbed streams. In fast moving scenes or between news when text scrolls it is barely readable. First I thought it is ffmpeg related then mumudvb, but actually it could be hardware/driver related. It happens on all streams and on both tuners. I use mumudvb do grab DVB-T streams and send them to multicast.
Any idea why is it happening?
These "interlaced effect" I get when watching a grabbed DVB-T multicast stream on laptop (VLC) and on android IPTV with XBMC on a regular TV set (Samsung 42"). Could it be resolution related? IPTV STB connects full HD with the TV set while the grabbed stream is at 720x576?
Input stream:
ffprobe -i udp://239.100.0.0:1234
Input #0, mpegts, from 'udp://239.100.0.0:1234':
Duration: N/A, start: 77357.106233, bitrate: 192 kb/s
Program 1
Metadata:
service_name : SLO1
service_provider: RTV SLOVENIJA
Stream #0:0[0x78]: Video: h264 (Main) ([27][0][0][0] / 0x001B),
yuv420p(tv, bt470bg), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 50 tbr, 90k
tbn, 50 tbc
Stream #0:1[0x79](slv): Audio: mp2 ([4][0][0][0] / 0x0004), 48000
Hz, stereo, s16p, 192 kb/s
Stream #0:2[0x7a](slv): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:3[0x7b]: Audio: mp1 ([6][0][0][0] / 0x0006), 0 channels,
s16p
Unsupported codec with id 94215 for input stream 2
[STREAM]
index=0
codec_name=h264
codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
profile=Main
codec_type=video
codec_time_base=1/50
codec_tag_string=[27][0][0][0]
codec_tag=0x001b
width=720
height=576
has_b_frames=2
sample_aspect_ratio=16:11
display_aspect_ratio=20:11
pix_fmt=yuv420p
level=30
timecode=N/A
id=0x78
r_frame_rate=50/1
avg_frame_rate=25/1
time_base=1/90000
start_pts=6962200658
start_time=77357.785089
duration_ts=N/A
duration=N/A
bit_rate=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
extradata=
00000000: 0000 0001 0910 0000 0001 274d 401e 9a62 ..........'M@..b
00000010: 0168 48b0 4420 a0a0 a800 0003 0008 0000 .hH.D ..........
00000020: 0301 94a0 0000 0001 28ee 3c80 ........(.<.
DISPOSITION:default=0
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
[/STREAM]
Hardware:
TBS 5280
IBM x3650 2x quadcore X5365 @ 3.00GHz, 24GB RAM
Software:
#lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 13.10
Release: 13.10
Codename: saucy
#uname -a
Linux IPTV 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
# dmesg | grep video
[ 0.329664] pci 0000:01:06.0: Boot video device
[ 19.720935] Linux video capture interface: v2.00
[ 21.936989] cx231xx #0: cx231xx #0/0: registered device video0 [v4l2]
[ 21.937047] cx231xx #0: V4L2 device registered as video0 and vbi0
# lsmod
Module Size Used by
tbs5280fe 18969 2
cx231xx_dvb 18126 60
dvb_core 109805 1 cx231xx_dvb
cx231xx_alsa 17866 0
snd_pcm 102033 1 cx231xx_alsa
snd_page_alloc 18710 1 snd_pcm
snd_timer 29433 1 snd_pcm
snd 69141 3 cx231xx_alsa,snd_timer,snd_pcm
soundcore 12680 1 snd
cx25840 53326 1
ext2 72832 1
coretemp 13435 0
kvm_intel 138538 0
kvm 431315 1 kvm_intel
gpio_ich 13476 0
lpc_ich 21080 0
cx231xx 177864 2 cx231xx_alsa,cx231xx_dvb
videobuf_vmalloc 13560 1 cx231xx
cx2341x 28230 1 cx231xx
videobuf_core 25993 2 cx231xx,videobuf_vmalloc
v4l2_common 16391 3 cx2341x,cx231xx,cx25840
videodev 97653 4 cx2341x,cx231xx,cx25840,v4l2_common
v4l2_compat_ioctl32 16692 1 videodev
ibmpex 13193 0
ibmaem 17838 0
ipmi_msghandler 45306 2 ibmaem,ibmpex
ics932s401 13824 0
radeon 1402449 1
microcode 23518 0
ir_lirc_codec 12898 0
lirc_dev 19166 1 ir_lirc_codec
psmouse 97626 0
serio_raw 13413 0
ir_mce_kbd_decoder 12845 0
ir_sony_decoder 12549 0
rc_tbs_nec 12502 0
joydev 17377 0
ir_jvc_decoder 12546 0
ttm 83995 1 radeon
ir_rc6_decoder 12546 0
ir_rc5_decoder 12546 0
drm_kms_helper 52651 1 radeon
ir_nec_decoder 12546 0
mceusb 17693 0
drm 296739 3 ttm,drm_kms_helper,radeon
rc_core 26854 11 cx231xx,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,rc_tbs_nec,mceusb,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder
i2c_algo_bit 13413 1 radeon
i5000_edac 17405 0
edac_core 62312 2 i5000_edac
ioatdma 67292 6
i5k_amb 13146 0
dca 15130 1 ioatdma
shpchp 37032 0
mac_hid 13205 0
lp 17759 0
parport 42299 1 lp
ses 17363 0
enclosure 15179 1 ses
hid_generic 12548 0
usbhid 53014 0
hid 101512 2 hid_generic,usbhid
bnx2 84643 0
aacraid 95456 2
