TBS6590 and Windows 10
Postby farsan » Sat May 04, 2019 3:05 pm
I installed the card in my PC and added the proper drivers.
I can get all the free channels but not any scrambled at all!
I am not able to access the CI menu. I use MediaPortal with the latest update.
I also tried the card with DVBdream but with the same result.
Any with the same problem?
farsan
Re: TBS6590 and Windows 10
Postby steven » Wed May 08, 2019 6:08 pm
Hi Farsan
Which version of DVBDream you are using ? please send email to our suppport the best is setup the
remote we will havea check
Postby farsan » Thu May 09, 2019 12:53 am
When using MCE CI Tool v1.0.0.10 I get the message that it can´t find any card!
I am using MediaPortal primary. MP can find the card but not the CAM!
Regards
//Folke
farsan
Postby steven » Thu May 09, 2019 11:51 am
MCE tool is for windows media center if you use mediaport then do not need to use this
please download this dll
https://www.tbsiptv.com/download/common ... .0.2.2.zip
and replace the mediaportal one or use this latest version of DVBDReam :
https://www.tbsiptv.com/download/common ... _v2959.zip
thanks
Postby farsan » Thu May 09, 2019 3:11 pm
Hi!
I tried the new .dll but there is no change, Only unencrypted channels.
I don´t intend to change my viewer because I use a setup with one separate TV-server which distribute to different clients in my home.
I also have two other cards for this purpose from DVBSky which are working well.
But I certainly would like to use my TBS6590 in the setup.
Regards
//Folke
farsan
Postby steven » Thu May 09, 2019 6:35 pm
using DVBDream just for testing the CI check whether is ok ,and we are on checking with MP check whether can get some information
any update we will send here
KindRegards
Postby farsan » Thu May 09, 2019 7:19 pm
Ok!
Will do!
//Folke
farsan
Postby farsan » Thu May 09, 2019 7:58 pm
Hi!
Tried the Viewer you sent but with no success!
I get an error code 5 and a message saying it can´t find any DVB hardware!
If I use MediaPortal I can access the card and scan for channels. Then I can see a list of all channels including the scrambled ones.
But I can only watch the unscrambled ones.
//Folke
farsan
Postby farsan » Thu May 09, 2019 8:09 pm
Hi!
For information:
My motherboard is ASUS PRIME H370/B360
//Folke
farsan
Postby steven » Fri May 10, 2019 9:59 am
HI
\when you using DVBDream do you have stop the MP service ?
is it possiblem send email to our support and setup a remote we will have a remote check
thanks
KindRegards
