TBS6909 sound problem
Postby Arty » Thu Oct 08, 2020 1:58 pm
I am using tbs 6909 + Ubuntu LInux 18.04 + tvheadend. I'm receiving video channels from satellite that is located at 58 degrees (Express AT1). I have two cords attached to the card. Tvheadend was able to detect 8 interfaces where I was able to attach different networks. For each interface I have attached a separate network that uses 1 mux.
I can get about 10 channels from each mux.
The main question is, how many channels I get from a single tuner using TBS 6909 card?
I'm facing a problem. When I try to stream multiple channels some of them start to lose sound. All of them have video stream but a lot of them lack sound. This only happens when I try to stream more than 5 channels.
Arty
Re: TBS6909 sound problem
Postby steven » Fri Oct 09, 2020 11:04 am
Hi Sir
For 6909 it have 8 tuners so you are able receive 8xTransponders at the same time . but you need to make sure that one tuner one transponder
if you use 1 tuner scan 8 transponders these 8 transponders can not use at the same time you need setup the 8 tuners one by one
kind Regards
Postby Arty » Fri Oct 09, 2020 1:16 pm
Thanks for your reply. I followed your advice and set up my map like this.
How many channels can you get from one tuner without problems with image or sound?
Arty
Postby steven » Fri Oct 09, 2020 2:28 pm
If your network is good you can streaming all channels inside the transponder
Postby Arty » Fri Oct 09, 2020 2:45 pm
Steven , thanks for your reply.
That is, in theory, I can use 8 transponders for 8 tuners. And get all the channels that I can find at the same time. With no restrictions ?
Arty
Postby steven » Sat Oct 10, 2020 2:34 pm
yes you can get all channels inside the 8 transponders you are using
Postby Arty » Mon Oct 12, 2020 6:50 pm
Sorry, Steven
How many channels can I stream simultaneously from one tuner?
Arty
Postby steven » Tue Oct 13, 2020 5:40 pm
one tuner one transponder and all channels inside this transponder
