driver problem
driver patch
Postby ashki » Sun Oct 28, 2012 3:47 pm
hello I've got a Qbox S2 usb card but its driver does not support blind scan can u upload a driver and add I2C access to it
pls i need the driver
ashki
Re: driver patch
Postby steven » Mon Oct 29, 2012 9:20 am
Hi ashki
We are sorry that QBox2 do not support Blindscan so we have not added the Blindscan support for
Qbox2.
Re: driver patch
Postby updatelee » Mon Oct 29, 2012 12:38 pm
you using linux or windows ?
if your in linux and if the qboxII uses stv090x or stv0900 which I belive it does then you can use blindscan and spectrum analyzer functionality. Windows is all closed src, you get what your given. Linux you dont like it ? rewrite it yourself.
works for me, I like that mindset :)
Re: driver patch
Postby crazycat » Mon Oct 29, 2012 11:08 pm
ashki Wrote:hello I've got a Qbox S2 usb card
what model number - 5920, 5928, 5921 ?
