Home > Products > DVB-S2 TV Tuner PCIe
Internal digital satellite TV tuners with PCI Express interface . Satellite single tuner, dual tuner, quad tuner TV cards. TV card with CAM slot.
  • TBS6920 is a PCI Express interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receiving. It’s ready with Windows BDA driver and Linux driver up to the latest kernel...    more >>
  • TBS6921 is the successor of TBS6920 with new generation Trident RF/Demodulator chipsets. It’s designed to fulfill the needs of watching satellite TV in front of a computer. It supports DVB-S2 and DVB-S backwards broadcasting. It’s ready with Windows BDA driver and Linux driver up to the latest kernel...    more >>
  • TBS6922 is a PCI Express interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receivi...    more >>
  • TBS6925 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6925 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also CCM, ACM, VCM, Multi Input Stream, 16APSK,32APSK...    more >>
  • TBS6928 is a PCI Express interface digital satellite TV Tuner card for watching and recording digital satellite TV on PC. With integrated CI slot, it can be used for watching Free to Air TV and Pay TV(if correct CAM and subscription smartcard are equipped)...    more >>
  • TBS6981 is a PCI Express interface digital satellite TV Tuner card with two tuners for watching and recording Free to Air satellite TV on PC. The two tuners enable you to watch TV channel from one transponder/satellite while recording another channel from another transponder/ satellite in the same time...    more >>
  • TBS6984 is a PCI Express interface digital satellite TV Tuner card with four tuners for watching and recording Free to Air satellite TV on PC. The four tuners enable you to watch TV channel from one transponder/satellite while recording three other channels from different transponders/satellites in the same time...    more >>
  • TBS6991 is a Twin Tuner digital satellite TV card with PCI Express interface for watching and recording digital satellite TV on PC. You may use one tuner to watch one TV channel while using another tuner to record/watch another channel from another transponder/ satellite simultaneously...    more >>
FAQ Center
Copyright © TBS Technologies 2005-2012 All Rights Reserved.
Home | Contact us | About us | Distributors | Site Map
