Home > Products > DVB-T2 TV Tuner PCIe
ASI Capture Card
HD Video Decoder
TBS2660 Professional H.265 IP Video decoder
  • TBS6221 DVB-T2/T/C TV Tuner PCIe Card is a digital terrestrial tuner card with DVB-C function added, which allows you to enjoy free-to-air (FTA) digital terrestrial/ cable TV and digital stereo r...    more >>
  • TBS6205 is a DVB-T2/T/C TV quad tuner card with PCI-Express interface, it can be used for watching four different channels from four different frequencies simultaneously, and it supports DVB-C sta...    more >>
  • TBS6209 is a DVB-T2/C2/T/C/ISDB-T TV Octa tuner card with PCI-Express interface, it can be used for watching eight different channels from eight different frequencies simultaneously, and it sup...    more >>
  • TBS6281SE is a dual tuner PCI-Express interface DVB-T2/T TV Tuner Card which supports watching or recording two different channels from two different frequencies simultaneously. TBS 6281 DVB-T2/T ...    more >>
  • TBS6290SE is the latest DVB-T2/T/C PCI Express tuner, it’s equipped with dual tuner and dual CI slot, which allows you to enjoy two live terrestrial TV channels from two different frequencies a...    more >>
Copyright © TBS Technologies 2005-2016 All Rights Reserved.
