TBS USB DVB-C TV Stick
This is a mini size digital cable TV stick with USB connection for watching and recording clear/unecrypted digital cable TV on PC. Windows BDA driver are provided.
- Description
- Specification
- Picture
- User Guide
TBS USB DVB-C TV Stick is the smallest TV dongle for watching/recording digital cable HD TV on PC, especially on laptop. Enjoy the digital cable TV on laptop and PCs.
Watch Cable TV & listen to Radio on PC
DVB-C SD or HD TV Receiving
Specifications:
Fully compliant with DVB-C and ITU J83 A/C Specifications
Receiving Frequency: 47~862 MHz Tuning Range
Input level: -65~-10dBm
16QAM, 32QAM, 64QAM, 128QAM and 256QAM Support
Symbol Rate: 0.87 to 9Mbaud
TV Stick Size: 92x28x12mm (Length x Width x Height)
TV Stick Weight: 20 Gram
System Requirements:
Windows 2000/XP/Vista/7
DirectX9.0 or later Version
Available USB Port
Cable TV connection
For HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS USB DVB-C TV Tuner Stick
1 x remote control
1 x IEC to F type connection converter
1 x Software CD
