Home > Products > DVB-C TV Tuner PCIe > TBS6680 DVB-C Dual Tuner Dual CI PCIe Card
ASI Capture Card
HD Video Decoder
TBS2660 Professional H.265 IP Video decoder
TBS6680 PCIe DVB-C Dual Tuner Dual CI Card- Digital Cable TV on PC
TBS6680 is a Dual tuner digital cable TV internal card with Dual common interface. It can be used for watching clear QAM or encrypted Pay TV (By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay TV will be available). Windows BDA driver is provided and Linux driver is also available. TBS6680 is compatible with MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV, VDR and many other popular softwares.
TBS6680 DVB-C Dual Tuner Dual CI PCIe Card, built with two Common Interfaces which allows insertion of CAM and smartcard for pay TV, is a good choice for watching/recording digital cable HD TV on PC.
Watch Cable TV & listen to Radio on PC
2 x DVB-C SD or HD TV Receiving simultaneously
2 x Common Interface Support
Copyright © TBS Technologies 2005-2016 All Rights Reserved.
