TBS6920 DVB-S2 TV Tuner PCIe Card
TBS6920 is a PCI Express interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receiving. It’s ready with Windows BDA driver and Linux driver up to the latest kernel. It’s compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
- Description
- Specification
- Picture
- User Guide
As computer technology develops, PCI Express is designed to replace the older PCI bus standard with numerous improvements. latest computer motherboards are having more PCI Express slots and less PCI slots, some of them even don’t have PCI slot any more. TBS6920 DVB S2 TV tuner card is designed for these new computers with PCI Express slot. It’s a good choice for watching/recording satellite TV on computer. You can use it to watch UK Freesat or any other satellite TV programs in your region..
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Broadband Internet via Satellite *
High-speed Data download via Satellite *
*Depends on service provider.
Specifications:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 10~30Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Low profile size: 130x80mm (Length x Height)
System Requirements:
Windows 2000/XP/Vista/7 or Linux
DirectX9.0 or later Version
Available PCI Express x1,x4, x8 or x16 slot
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS6920 PCI-E DVB-S2 TV Tuner Card
1 x remote control
1 x IR receiver
1 x Software CD
