TBS6921 DVB-S2 TV Tuner PCIe Card
TBS6921 is the successor of TBS6920 with new generation Trident RF/Demodulator chipsets. It’s designed to fulfill the needs of watching satellite TV in front of a computer. It supports DVB-S2 and DVB-S backwards broadcasting. It’s ready with Windows BDA driver and Linux driver up to the latest kernel. It’s compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
- Description
- Specification
- Picture
- User Guide
TBS6921 is a low profile PCI Express DVB-S2 TV Tuner card. You can use it to watch UK Freesat or any other free to air satellite TV programs in your region.
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Broadband Internet via Satellite *
High-speed Data download via Satellite *
Unicable/One Cable compatible
*Depends on service provider.
HTPC
IPTV Streaming Server
Specifications:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 1~45Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Low profile size: 143x56mm (Length x Height)
System Requirements:
Windows 2000/XP/Vista/7 or Linux
DirectX9.0 or later Version
Available PCI Express x1,x4, x8 or x16 slot
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS6921 PCI-E DVB-S2 TV Tuner Card
1 x remote control
1 x IR receiver
1 x Software CD
