Home > Products > Products > DVB-S2 TV Tuner PCIe > TBS6925 DVB-S2 Professional TV Tuner PCIe Card
TBS6925 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6925 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also CCM, ACM, VCM, Multi Input Stream, 16APSK,32APSK,Generic Stream Mode which most satellite receiving devices can’t support. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are ready.
TBS6925 PCI-E DVB-S2 Professional TV Tuner card, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream, 16APSK,32APSK or Generic Stream Mode. The built in hardware blind scan feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. Such blind scan feature can be achieved by dedicated TBS tool or Crazyscan tool.
DVB-S2/S Transponders Receiving
CCM, VCM,ACM and Multi Input Stream Support
Generic Stream Mode Support
Up to 190 Mbit/s channel bit rate capture
Wide range symbol rates support from 200Ksps to 45Msps
High-speed Data download via Satellite
Unicable/One Cable compatible
Blindscan
High reliability
*Depends on service provider.
Satellite feed hunt
Satellite Data download
Lock of special transponders
FAQ Center
Copyright © TBS Technologies 2005-2012 All Rights Reserved.
Home | Contact us | About us | Distributors | Site Map
