Home > Products > DVB-S2 TV Tuner PCIe > TBS6991 DVB-S2 Dual Tuner Dual CI PCIe Card
TBS6991 is a Twin Tuner digital satellite TV card with dual common interface for watching and recording digital satellite PayTV on PC. You may use one tuner to watch one TV channel while using another tuner to record/watch another channel from another transponder/ satellite simultaneously. It can be either used for watching Free to Air TV or satellite Pay TV since it’s integrated with two CI slots(By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay tv will be available). This device is provided with both Windows BDA driver and Linux driver up to the latest kernel. The unique TBS MCE tool makes it possible to read CAM/Smartcard on Windows7 Media Center, thus your satellite subscription TV can be watched/recorded on Windows7 Media Center. On Linux platform, you can also watch PayTV by using relative software on Linux. TBS6991 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
TBS6991 PCI-E DVB-S2 Dual Tuner Dual CI card is the high end satellite TV tuner built with dual Common Interface support, which allows insertion of two CAMs and two smartcards for recording two different paytv channels at the same time. It’s good choice especially for IPTV server streaming PayTV contents. With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your iPhone, iPad or iPod. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Dual Tuner for Recording Two Different Channels/Transponders
Unicable/One Cable compatible
Dual Common Interface Support
Blindscan
High reliability
HTPC
IPTV Streaming Server
FAQ Center
Copyright © TBS Technologies 2005-2012 All Rights Reserved.
Home | Contact us | About us | Distributors | Site Map
