TBS7610 is a mini PCIe interface digital cable TV Tuner internal card for watching and recording digital cable TV on PC. With its’ mini size(30x60mm), TBS 7610 fits the need of receiving DVB-C TV channels on some mini ITX motherboard which has only Mini PCI Express interface. Windows BDA driver are provided and Linux driver will be released in the near future.
- Description
- Specification
- Picture
- User Guide
TBS7610 Mini PCIe DVB-C TV Tuner Card, the smallest digital cable TV internal card in the world, is a good choice for watching/recording digital cable HD TV on PC.
Watch Cable TV & listen to Radio on PC
DVB-C SD or HD TV Receiving
Specifications:
Fully compliant with DVB-C and ITU J83 A/C Specifications
Receiving Frequency: 47~862 MHz Tuning Range
Input level: -65~-10dBm
16QAM, 32QAM, 64QAM, 128QAM and 256QAM Support
Symbol Rate: 0.87 to 9Msps
TV Card Size: 60x30mm (Length x Width)
TV Card Weight: 80 Gram
System Requirements:
Windows 2000/XP/Vista/7
DirectX9.0 or later Version
Available Mini PCI Express slot
Cable TV connection
For HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x TBS7610 PCIe DVB-C TV Tuner Mini Card
1 x remote control
1 x Software CD
