PC build for capture multiple DVB-T2 and HDMI sources
Postby mourn » Tue Dec 15, 2020 4:55 am
I'm trying to build a PC (or two given the issues I'll talk later) with multiple DVB-T2 and HDMI (like satellite decoders) PCIe capture cards .
For the DVB-T2, I'm particularly interested in this two models
- TBS6281 Dual tuner
- TBS6209 Octa tuner
From what I understood theese cards can record respectively 2 and 8 channels from different mux at the same time, right?
I need to know if these cards have a dedicated chip for encoding/decoding or they use CPU or GPU, so I can understand which hardware I have to use for build the PC.
Before I talked about PCs because it's likely that I'll install both these cards (or two of them, most likely two 6209) in the same PC.
I guess I can't open two instances of the same software used by the same cards in the same environment/operating system, so could use one of the cards with her software on a virtual machine solve this issue (if this is an issue...)?
Thanks in advance and sorry if my English is bad.
I'm always available for further informations.
mourn
Return to General discussion
Users browsing this forum: No registered users and 24 guests
