Spotify on MatrixPC - XBMC
Postby mijanek » Mon Jan 20, 2014 2:12 pm
Hi everyone, I was able to install the spotify plugin spotimc on the current matrixtv. I slightly changed the package from azkotoki
so it can be installed on the matrix device. (Removed dependecy check and added armv7 lib from spotify) It is working fine with my premium account.
You may download the modified pakage here
mijanek
Re: Spotify on MatrixPC - XBMC
Postby mijanek » Tue May 20, 2014 4:32 pm
Hi everyone, Azkotoki released new version of its spotymc - script.audio_.spotimc-1.0-beta5.
As previous version I adjusted it to be installable on Matrix device. (Removed dependecy check and added armv7 lib from spotify).
You may download the modified package here
mijanek
Postby mijanek » Tue May 20, 2014 5:51 pm
Just in case someone gets problem of "5 sec " playback only, than follow this advice form xbmc support thread
Just go to System / Addons / Enabled Addons / Services / CU LRCLyrics / Configure, and uncheck "Search for embedded lyrics" on the scrapers tab.
mijanek
Return to Development
Users browsing this forum: No registered users and 13 guests
