Where is TBS 2910 dvb usb files.
Postby BTopbas » Sun Dec 21, 2014 4:35 pm
Hi, i cloning source code of matrix tv. What folder name is have tbs drivers? Where is it?
BTopbas
Re: Where is TBS 2910 dvb usb files.
Postby vpeter » Sun Dec 21, 2014 6:03 pm
There is no drivers anywhere. TBS drivers are closed source and only available in official kernel.
vpeter
Postby BTopbas » Sun Dec 21, 2014 6:15 pm
So, openelec port for 2910 not support tbs dvb devices?
BTopbas
Postby vpeter » Sun Dec 21, 2014 6:28 pm
Only some opensource ones like ljalves media_build. Tested only USB tuner and it works. For PCI don't have any hw to test.
vpeter
Postby BTopbas » Sun Dec 21, 2014 7:58 pm
I tested ljalves driver on raspberry pi(armv6) but not working. Most channels not working.Gives No data error. I try tbs device on ubuntu pc with kaffeine like work a charm. No problem. All channels working. But on raspberry pi(armv6) only 1 or two channel works others gives no data error. Now ı buyed new amlogic device. Deliver tomorrow or tuesday. I test ljalves on this device(armv7, same cpu tbs 2910). If not working like raspberry pi i record videos about tbs. And i fix tbs's lie. I mailed tbs support for this topic but they not give me answer. Tbs advertise dvb's devices full support linux support. But only work pc. And they dont realese open source. Support is terrible. I warning peoples about tbs on youtube channel and my facebook pages.
Cheers.
BTopbas
Postby vpeter » Sun Dec 21, 2014 8:06 pm
From the feedback I got back that TBS5980 (and maybe TBS5922) was working. How don't know.
If you want fully supported card you don't buy tbs ones. You should already know that. Only x86_64 and i386 is supported in their binary drivers and nothing else. Sadly. But who cares.
vpeter
Postby BTopbas » Sun Dec 21, 2014 8:45 pm
Tbs says arm mini pc tbs2910 fully supportted tbs dvb usb devices. Okey. I know matrix pc is support devices with no problem. But ı dont know why closed source? my new amlogic device have same cpu on the tbs matrix pc. They need to realese armv7 drivers. Nevermind.
BTopbas
Postby vpeter » Sun Dec 21, 2014 11:17 pm
Your Amlogic device doesn't have i.mx6 soc - it does have one amlogic one (which is arm based).
And about closed source drivers: it's their rights ;)
vpeter
Return to Development
Users browsing this forum: No registered users and 17 guests
