TBS6983 streamreader gse bad crc-32
Postby bardoc » Wed Jan 16, 2019 6:11 pm
Hi crazycat,
I am trying to write a gse stream to a file using crazysan, and in the resulting stream almost all GSE packets with an incorrect CRC-32.
If I record a stream using TBS TSRecorder, then all CRC-32 in all GSE packets is correct.
I tried StreamReader.dll 1.2.4.74, 1.2.4.52
Problem in wrong CRC-32 in GSE packet
Thanks!
bardoc
Re: TBS6983 streamreader gse bad crc-32
Postby bardoc » Thu Jan 17, 2019 8:01 pm
Problem solved.
I found streamreader.dll version 1.2.2.1270 in which the correct crc-32 at the end of gse packet (at the first blush).
bardoc
