Getting TBS6908 running on HP Gen 9 Series
Postby davidtorres » Tue Aug 22, 2017 5:33 pm
I wanna to install a TBS cards on an HP Gen 9 machine (updated to the latest BIOS firmware), which compromised of two E5-2609v3 processors and 32 GB of DDR4 RAM. The cards and their drivers are installed (on Windows 7, 10 and Linux). However, I cannot lock TBS Recorder on a frequency, which I've just found using Blind Scan!
Can anyone Help me, please?!! :cry:
davidtorres
Re: Getting TBS6908 running on HP Gen 9 Series
Postby steven » Tue Aug 22, 2017 8:54 pm
Hi davidtorres
Which frequency and satellite ? and for the BS scan result maybe some transponder signal is not very well need better signal
Postby davidtorres » Sun Aug 27, 2017 2:49 pm
Hi Steven
The weird thing is that the card is working on an HP workstation z420 machine with a Xeon processor E5-1620! Using the aforementioned HP Gen 9, I cannot lock on any frequency of any satellite!
Thanks.
davidtorres
Postby steven » Mon Sep 04, 2017 9:51 am
Hi davidtorres
Do you have connect the extra power for your 6908 ?
Postby davidtorres » Mon Sep 04, 2017 1:30 pm
Dear Steven,
No, I did not use extra power. How much power does it require?
Thanks.
davidtorres
Postby steven » Tue Sep 05, 2017 11:40 am
Hi davidtorres
It is 12V you can using the power cable coming with 6908 card connect to your power supply .
Postby davidtorres » Tue Sep 05, 2017 2:15 pm
Thanks a lot Steven. I will test it and will let you know about the effect of using extra power.
davidtorres
Postby davidtorres » Thu Sep 14, 2017 1:17 pm
Steven,
It does not work! I've used the power cable, but it did not locked on any frequency! I wonder why it cannot lock on HP Gen 9!
Thanks.
davidtorres
