Can't make TBS6909 to work in Unicable/JESS mode
Postby malakudi » Mon Oct 01, 2018 10:33 pm
I have a few TBS 6909 and one Unicable 2 (aka JESS) multiswitch from Technisat, model Technirouter 9/4x16. It supports 4 satellites with wideband LNBs or 2 satellites with Quattro LNBs, and has 4 outputs with 16 SCR addresses each.
I have configured TBS 6909 with mode=2, connected output cable from multiswitch on Tuner 3 as shown in documentation, but I can not get signal with any Linux program I have tried, which includes w_scan, mumudvb and tvheadend of course.
For example, I use w_scan with:
w_scan -a 0 -s S19E2 -fs -u 0:1210:a to select Astra 1 (19.2E) on SCR id 1, frequency 1210 MHz. But nothing is scanned.
On same multiswitch output, I have tested an enigma2 STB (VU+ Zero) and configured it with same settings (SCR id 1, frequency 1210 MHz) and worked fine. Obviously I have also tried other SCR ids and frequencies but none works on TBS card, all work on STB.
Any hint? I am a bit desperate now.
malakudi
Re: Can't make TBS6909 to work in Unicable/JESS mode
Postby malakudi » Tue Oct 02, 2018 3:04 am
How is Unicable going to work with mode 2, if the code in mxl58x.c does nothing for set_voltage?
static int set_voltage(struct dvb_frontend *fe, enum fe_sec_voltage voltage)
   struct mxl *state = fe->demodulator_priv;
   struct i2c_adapter *i2c = state->base->i2c;
   struct mxl58x_cfg *cfg = state->base->cfg;
   switch (mode) {
   case 2:
         break;
Unicable communication requires setting voltage to 18V, then sending diseqc command, then returning to 13V. What is going on here? Does it really support Unicable in mode 2?
malakudi
Postby malakudi » Tue Oct 02, 2018 10:13 pm
Tested with different pc satellite card and my setup works fine. With TBS 6909 I managed to work in mode 1 but only with EN 50494. It seems diseqc commands starting with 70 are blocked, so EN 50607 is not working. In mode 2 nothing works.
Can you provide a workaround?
malakudi
Postby malakudi » Wed Oct 03, 2018 2:48 pm
Fixed the issue. It has been mentioned in drivers git since January but nobody noticed - although the fix proposed there was not optimal.
https://github.com/tbsdtv/linux_media/issues/102
Here is the correct fix:
--- mxl58x.c   2018-10-03 09:19:29.000000000 +0300
+++ mxl58x.c   2018-10-03 09:31:47.128176219 +0300
@@ -801,7 +801,6 @@
    switch (mode) {
    case 2:
-         break;
    case 1:
       cfg->set_voltage(i2c, voltage, state->rf_in);
       break;
@@ -824,7 +823,6 @@
    switch (mode) {
    case 2:
-         break;
    case 1:
       set_input_tone(fe, tone, state->rf_in);
       break;
Please update git
malakudi
Postby jdrr » Wed Oct 17, 2018 2:23 am
I also have a 4 satellites system with Unicable II, however, I can not seem to get it to work.
I only get something in mode = 1 and only the satellites A and B.
jdrr
