problem with tbs & dvbsky
Postby some1 » Wed Feb 10, 2016 12:18 am
hello,
I have dvbsky pcie card. I installed their driver by compiling mediabuild from thier website.
once I installed your driver the dvbsky driver stopped working.
so I installed their driver again and now your driver stopped to work again.
what should I do so both card can work together?
thanks for your help.
(OS ubuntu 15.10, tbs I have is 6909)
some1
Re: problem with tbs & dvbsky
Postby SergioDanielG » Wed Feb 10, 2016 1:32 am
Hi some1.
TBS drivers replace all kernel media. If dvbsky drivers do same, it's very dificult to do both cards works toggether.
Kind regards.
SergioDanielG
Postby some1 » Wed Feb 10, 2016 3:03 am
dvbsky is using liplianin version for kernel media.
it's a very common drivers. so I can't use both cards on linux? :(
thanks again.
some1
Postby SergioDanielG » Wed Feb 10, 2016 3:32 am
If you know which module used your device, you can compile it and install them on tbs drivers.
See this topic viewtopic.php?f=86&t=9727&p=34922#p34922 maybe not exactly that you need but you can try...
Kind regards.
SergioDanielG
Postby some1 » Wed Feb 10, 2016 4:02 am
great, thanks for the direction. I will try this. :)
some1
