TBS 6904 X , DVBViewer and Diseqc
Postby rpc » Wed Oct 24, 2018 2:56 pm
since there is no 6904x-section, I hope it is OK to post it here.
I just bought a new 6904x from you, and I would like to use it together with my existing 6922 with current versions of DVBViewer & Media Server. Unfortunately, Diseqc seems to be a big problem, I can only watch programs on satellite position A/A (default diseqc 1.0) with the 6904x. My 6922 shows no problems on the same computer and at the same time with Diseqc.
I am on Windows 10 1803, and tried driver versions 1.0.0.1 and 1.0.0.3.
Is there anything that can be done to get it to work? Thank you.
rpc
Re: TBS 6904 X , DVBViewer and Diseqc
Postby rpc » Thu Oct 25, 2018 2:17 am
Problem solved:
Since the card is pretty new, it is unknown so far by DVBViewer, to get it recognized, edit file hardware.xml or svchardware.xml and change entry "Vendor" from 0 to 31.
rpc
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
