Stream-Key Format not Accepted
Postby df3ei » Thu Dec 27, 2018 2:53 pm
Hi, all,
I recently upgraded my box to firmware version 1.1.87. Since then I cannot get HDMI 1 to persist a stream key like so: 'stream-123456'. Note the hyphen! It seems to accept it on HDMI 2, and also accepts separators like underscore (like what Twitch uses), but not hyphen.
I assume this is a bug, so hoping this will be fixed soon, as I cannot use the box as it is now (luckily I have a second one). As an aside: what is the procedure for downgrading a firmware, as that would be a workaround to get the box working again.
Thanks,
Jörg
df3ei
Re: Stream-Key Format not Accepted
Postby echomay » Fri Dec 28, 2018 2:34 pm
Which version of your encoder before upgraded?
You can asked me from mail: echo@tbsdtv.com for the old version firmware.
echomay
Postby amroe » Wed Jan 16, 2019 11:54 pm
I think tis is the problem for all of us why ? Becuse i had tryed to connect to multiple RTMP Server without Any Success .
FaceBook No
YouTube No
Twitch No
Restream.io No
Xtream Codes 1.6 RTMP yes why ? Becuse of simple Stream key i had used like in Picture
This is Only what Worked with Me.
amroe
Postby diabloss » Mon Jan 21, 2019 2:29 pm
amroe Wrote:I think tis is the problem for all of us why ? Becuse i had tryed to connect to multiple RTMP Server without Any Success .
FaceBook No
YouTube No
Twitch No
Restream.io No
Check please here
viewtopic.php?f=187&t=25051
diabloss
Postby amroe » Wed Jan 23, 2019 1:46 am
i had read all topics without Success .
amroe
Users browsing this forum: No registered users and 21 guests
